Removed screws that held settee base and added two fiddles that fit inside the cabinet frame. Used left over screws to secure the fiddles. It fits snug and lifts right up. No cabinet modifications needed.
Did the same with the starboard side, but only one fiddle needed. As with the port side, no cabinet modifications needed, they lift right up, but remain secure when replaced.
