Hunter 49 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H49 Specs
posted 09-12-2008 by Bill Kahn
Length Overall 4911 15.21 m
Hull Length 4710 14.58 m
Waterline Length 4310 13.36 m
Beam 149 4.47 m
Draft (Shoal) 56 1.68 m
Draft (Deep) 70 2.13 m
Displacement 32,813 lbs 14,884 kg
Ballast (Shoal) 12,544 lbs 5,690 kg
Ballast (Deep) 11,216 lbs 5,087 kg
Mast Ht From Waterline 634 19.3 m
Mast Ht From Waterline � Optional Tall Rig 686 20.9 m
Sail Area � Standard 1,277 sq ft 118.64 sq m
Sail Area � Furling w/Vertical Battens 1,161 sq ft 107.86 sq m
Sail Area � Cutter Rig 1,316 sq ft 122.26 sq m
Additional Sail Area w/Tall Rig, Furl Opt 97 sq ft 9.01 sq m
w/110% Overlapping Jib Option 77 sq ft 7.15 sq m
I 547 16.64 m
J 166 5.03 m
P � Standard 517 15.73 m
P � Furling 507 15.42 m
P � Tall Rig Option 559 16.99 m
E � Standard 2110 6.65 m
E � Furling 239 7.24 m
Headroom 69 2.06 m
Fuel Capacity � Standard 150 gal 568 liters
Fuel Capacity � Optional 222 gal 840 liters
Water Tank Capacity 200 gal 757 liters
Holding Tank Capacity 52 gal 197 liters
Water Heater 11 gal 42 liters
Inboard Engine � Standard 75 hp 56 kw
Inboard Engine � Optional 100 hp 75 kw
CE Category A/13
