Hunter 380 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H380 Installed Trojan T-105s.
posted 10-07-2008 by Marty Warble
See Trojan T105s, starter battery, and inverter
Full view of Trojan T-105s, starter battery, and inverter installed under port settee in Hunter 380.
See Looking down on T-105s and starter battery
This picture shows the Trojan T-105s and starter battery installed in the forward part of the port settee of the H-380.
See Battery box used.
This is a picture of the battery box I used for the Trojan T-105s. One box holds 2 batteries. The box had to modified in order to fit in settee. The lip had to be removed and the lids had to made more shallow to fit vertically under the settee. The box was purchased from www.powerstridebattery.com. Heres a link: http://www.powerstridebattery.com/store/getproductframe.cfm?category=Specialty Cables and Accessories
Click image for largest view
