Hunter 376 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Home Made Radar Arch for 376
posted 10-07-2008 by Don Alexander
Made from 1 OD SS tube in a hurry the day before holiday cruise.
Only intended to be temporary - but that was 4 years ago.
Scanner Arch - General View
Just used 4 SS jubilee clips done up V tight.
Amazingly you cannot move the arch as the clips are so good.
Attachment to Pushpit
Made a small 1/8 thick alum alloy plate to take the JRC 1000 scanner.
Plate is attached to horizontal tube with two saddle clamps straight from chandlers.
It is prevented from rotating by a self tapping screw through each clamp and into the tubing.
Sorry picture is so compressed that the details dont show very well.
Alloy Scanner Plate
Click image for largest view
