Hunter 376 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Windlass chain
posted 09-12-2008 by Jon Petersen
If you put out more than 100 feet of chain .. it jams up.. so if you look at the old inputs.. Use 3inch PVC pipe and reroute the chain drop... Very helpful. I did it and now I can put out 200feet of chain and it all comes back in.. (This is for the Hunter installed Windlass...)
