Hunter 37.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
37.5 Anchor Winlass Installation
posted 10-07-2008 by
See Deck switch
Deck Switch installed just to the port side of winch. Can use foot or knee to operate leaving hands free to arrange the rode in the locker I also installed an extra battery in the starboard side cockpit locker . The circuit breaker is also installed in battery locker.
See Rub strip
when hauling the anchor, I do have to coil the nylon rode. The chain falls into the locker on its own but i do arrange it in the locker every few seconds to keep it neat. Notice the rub strip installed to protect the edge of the chain locker
See In Vee Birth
I cut away the fiber glass over head linner and epoxied in a 1 plywood reinforcing ring for added strength. I am going to install a teak wood valance to hide the winch from eye sight when looking forward from salon.
See Chain Stopper
The chain stopper I used also helps keep the chain and Rode from popping up from the bow guide. I also installed a plastic /nylon type rub strip on the bow anchor guide. Can use starboard or some similar material which can be formed with a heat gun to conform to the bend in the anchor guide.
