Hunter 37.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
On Deck Windlass for Legend 37
posted 10-07-2008 by
See On deck installation of windlass
The windlass is directly behind anchor. The up and down foot switches are on the deck. If I was doing the job over again I would put the up switch inside the anchor locker so that when I sit on the deck with the locker open to feed the rode and chain into the locker I could work the switch with my foot.
See Windlass wiring
I installed a battery in the VBirth locker with a On/Off Switch
