Click for larger view
Windlass Installation on Legend 37.5
Author: Scott P. Nielsen
After researching the windlass issue, I chose the Five Oceans 2008RC-C-Series 1012 Anchor windlass (www.five-oceans.cm) and purchased it through Ebay ($800). In retrospect I wished I had chosen the windlass with a drum for going up the mast with less effort as my wife is not an Amazon.
The existing anchor locker on the 37.5 is somewhat shallow and putting in a Horizontal windlass or even a vertical with a downward chain pipe would mean reconfiguring the locker so that the windlass could sit in or on the locker hatch. In this view you can see that the unit is not centered on the deck. This is because the anchor roller on the 37.5 feeds in at an angle and not directly in from the bow. By mounting the windlass a little off of center the feed to the bow roller is more of a straight line. It still requires clearing the line after the chain is all in, (In testing, the weight of the chain allows the chain to feed into the locker without assistance) as it comes in. I researched and pondered for over a year and a half before I actually cut holes and installed the windlass. In my research and input from those who have tackled this on the 37.5 and 35.5, I thought there was a better way to put this puppy in. What I ended up doing is using 2/0 welding cable as it is much cheaper than Anchor marine grade cable and can certainly handle the amps with virtually no voltage drop. After install the voltage at the solenoid is the same as at the battery. I did not like the idea of putting a battery in the forward compartment or mounting the solenoid in the hanging locker. I did not want to make the cable run go up and down the settee’s as this adds length and potential voltage drop. However, I complement those who gave me input, especially Alex Lopez’ installation on a 35.5, and applaud their installations as their installs work for them and gave me the mousetrap to improve upon for my installation. The HOW is a great group of sailors as all the different owner groups are. I would not have come to the method I used without them or their inputs. My basic requisites for installation were to minimize holes penetrating the deck, provide ease of access after installation, minimize cable run, use existing battery location, cut as few holes in bulkheads and such as possible. I feel I accomplished those requisites without compromise. I ended up with one hole in the deck for the windlass shaft and 4 holes for mounting bolts, one access hole in the shower, and two drill holes from the anchor locker through the V-berth bulkhead easily sealed with marine grade RTV.
(Photo Windlass detail looking aft)
I had a machine shop cut an opening in my windlass so the chain would feed 180 degrees and into the locker so I did not need to modify or cut any holes for a chain pipe to the anchor locker.
The template provided by the mfg. worked well. I used a drill bit for the windlass base bolts and a hole saw for the shaft hole.
