Click for larger view
When I re-bedded the chain plates a few years ago, I used polysufide caulk (LifeCaulk); it was probably pretty good for three or four years. Eventually the bond between the caulk and the wood coring of the deck failed - it was still adhering well to the chain plates. By filling the holes with epoxy ans recutting the slots, the wood coore is now out of the equation. While I had the chain plates out, I cleaned them thoroughly and examined them very carefully with a 10X jewelers magnifying loupe. I paid particular attention to area that penetrates the deck and the area above the upper bolt hole. The inspection can also be done with a dye penetrant inspection kit, but I am confident there are no cracks. There was some very minor staining/pitting where leaking water had started a bit of pitting corrosion but polishing the chain plates with 120, 220, 400, 600 and 1000 grit sandpaper and finally rubbing compound brings them back to a near-mirror finish.
