Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Entertainment installation on H34
posted 10-07-2008 by Jerry Keto
This 20 widescreen (Toshiba) is trimmed in SS and has a waterproof remote. Its installed with a swivel arm that allows positioning to also be seen from v-berth. You can also see Ive installed a battery monitor, second 30amp main for winter use, and an Icom radio with Command mike in the cockpit. Behind and to the right of the tv is a Sony photo printer that allows me to preview pics on the tv before printing.
Entertainment center without cabinetry mods
Both units fit well on aft cabin shelf behind nav table
Home theatre and satellite reciever
Teak trim fastened to original facia prevent units from shifting.
Mounted to stay put
The left and right satellite speakers as well as the Yamaha subwoofer mount nicely under nav table. Center channel speaker is mounted behind and above tv. Left and right rears are mounted at bulkhead above shelf.
Speaker installation
Click image for largest view
