Click for larger view
One of the most annoying things about my H34 was trying to open and close the original line clutches. During our restoration, I finally replaced both sets with these Harken clutches that open and close with no effort at all. We added a third clutch on each side to enable reefing from the cockpit. Mounting was no problem as you can get access by removing the cabin ceiling inserts.
