Hunter 33.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
335 anchor roller and fly screens.
posted 10-07-2008 by Colin Campbell
The velcro on the screen is 1/4 wide, the self adhesive velcro on the boat is 3/4 wide this prevents the velcro from being pulled off the boat.
Screen with velcro attached.
I sewed this screen together to form a small tent shape. Then used velcro in the same manner as the other screens. Looks OK, works great.
Opening hatch screen.
Screen in place.
I built this anchor roller out of 316 stainless. It is through bolted with the nuts located in the anchor locker. Very pleased with the results apart from I should have used a better quality horn cleat, as you can see one horn of this plastic one broke off. When I built it, I drilled a hole on the centerline for no real reason other than I thought it might be handy. I picked up a used spinnaker dead cheap the other day that hole came in real handy for securing the tack of the spinnaker.
Home built anchor roller.
I am planning on twinning this roller. I will need to cut the existing one off the base plate and move it over to do this so we will see how the time and energy hold out.
Another view.
Click image for largest view
