Hunter 33_77-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H 33 manual bilge pump installation
posted 10-07-2008 by
See Manual Bilge Hose Pickup and Exit through Sole
The pickup for the 1 1/2 hose for the Gusher 10 installation is at the location of the aft most keel bolt and aft of the installed Rule automatic bilge pump. A plumb line from the middle of the forward edge of the lower ladder step is about the forward edge of the hose as it exits. In my boat the installer had made a slot forward from the round hole and then had to cover it with a piece of the teak and holly sole plywood. Hose then goes up under the ladder and through the engine room bulkhead
