Hunter 33_77-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
MACARA
posted 09-12-2008 by Rick Harvey
Bought this bought used in 2007.
1. Replace gate vale sea cock (wheel handle)with a new ball valve type. Much safer
2. Replace the cockpit drain hose and new clamps. Potential rupture could sink the boat!
3. Check RACOR filter and be sure to use proper filter element, probably 30 micron.
