Click for larger view
Completed installation. Nothing is visible. In order to operate the washer, one needs to lift the settee cushion and open the lid. The water connections are through normally closed relays (safe), the electric panel becomes accessible in the usual place. It takes around 40 min to complete a wash, it uses about 15 gallons of water and very little electricity. You need a water heater to make this mod worthwhile. The machine is around 1 cu ft.
