Hunter 30_74-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Durabak Non Skid Application 79 H30
posted 10-07-2008 by John Kathrein
The cockpit before we recoated.
We washed the deck, sanded it down with palm sanders, and cleaned it with Xylene.
Cockpit
Another view of the cockpit before we recoated it.
Cockpit #2
Cabin top before we coated. We removed all of the hardware.
Cabin top
I built new grabrails. The old ones were barely bedded down and I believe a source of a mystery leak.
Cabin top #2
Fore deck before recoating
Fore deck
Mast step before coating.The taping was a very laborious job. I used the 2 blue tape; but would try to use 1 next time and be verycareful when applying the coat. I used a variety of jar tops and coins to get the radius on small corners. I used short, overlapping segments of tape to do the large radius.
Mast step
This is one thick coat on the cockpit and seats. Looks pretty good, but I plan to apply another coat.
Overall, I used 2-1/2 gallons. I would buy Qts next time.
1st gallon did 2 coats on the cabin top and 1st coat on the foredeck. 2nd gallon did 2nd coat on foredeck, 2 coats on walkway, and 1 thick coat on cockpit.
Cockpit - After
Foredeck after applying 2 coats.
Foredeck - After
Cabin top after 2 coats. Grabrails installed.
Cabin top - after
Cabin top after 2 coats. New dropboards. Need to replace the rest of the woodwork.
Cabin top - after #2
Nice view of the front of the cabintop after 2 coats. Note how beefy the grabrails are.
Cabin top - after #3
Click image for largest view
