Hunter 30_74-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
1979 HUNTER 30 DODGER BIMINI
posted 10-07-2008 by Ian McGain
Doger is six sections with zippers and snap buttons. Dodger frame is one inch stainless bent on boat by Don Farmer of Farmer Canvas in Rock Hall, Md. Sunbrella is 10 oz with backing. Fly can be used only when under power or at the slip. Traveller is pulled to port and is set through cut-out. This works great for rainy weekends.
looking out, doger installed
Dodger set on frame is held in place by four white straps
A lot of times just use this without front and side pannels. Keeps rain and sun out of hatch when open.
Dodger without front and sides
Port view of set-up
port view
Here you can see the fly works with the traveller
bow- starboard side
last shot
Click image for largest view
