Hunter 30_74-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Adding Solar
posted 09-12-2008 by Charles Creel
First attemp at adding solar panel and charging system on 1979 h-30. panel is 130 watts kyocera . panel is mounted to bimini frame with 1/4 x 3 inch aluminum flat stock.
