Hunter 28.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Merriman steering
posted 09-12-2008 by Warren Milberg
If your steering system is similar to what is shown in the image below, its a simple matter to loosen the steering cables. The two steering cables wind around each quadrant and then are brought forward and terminate in two locknuts at the forward end of the quadrants. Just loosen the locknuts and youll be able to adjust cable tension easily.
