Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Another 260 table modification
posted 10-07-2008 by Darwin Smith
As with many other 260 owners, I thought the table was far to large for the cabin. I started by cutting one foot off the large end of the table like many others. Then since I had the saw plugged in I cut off the left side of the table too. This gives me access to the bow and the junk I keep up there.
The bracket was cut from a piece of high density polyethylene and holds the table a lot firmer than it was before.
Table support
I fastened the table leaf back to the table with a continuous hinge and two brackets to hold it in the upright position.
Table
Then I reattached the table trim and cleaned up the mess. We love the additional room in the cabin.
Table
Click image for largest view
