Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Baums Rush improvements 4
posted 10-07-2008 by John Baumgartner
port side curtains
you can see how I made these up, small stuff (line) goes around the brackets thru holes I drilled and made the bungy cord keep it tight
closer view port side
used velcro and sowed the male side to the screen and the female velcro glued to the linner
forward hatch bug screen
starboard side curtains
made the same way. Used glue to hold the brackets to the linner
forward ports curtains
from a 18 wheeler and a 12v fan
Floruresent light 12V
two of the three, port side
AC exhaust vents
below the pull handle sort of small it also tell me operation hours for maintance
O/B Tach
replaced the mirror that came with the boat
Medicine Cabnet
Note the deflector on the lower housing, I bought this on this site. It works great and well worth the price
another view of O/B
with autopilot, and bracket for the GPS/fish finder/chart plotter, throttle and gear control for motor
wheel steering
port side, same for starboard
Spinaker block
4 cycle, 4 HP
tender O/B bracket
This just about doubles the stowage space, more fuel or spair anchor..... etc.
shelves made above fuel locker
Click image for largest view
