Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Rainproof hatch panels
posted 09-12-2008 by John Denison and Pat Adam
If the pictures dont show click on the broken thumbnail or refresh the page. Some owners complain that water gets into the cabin of the H26/260.
Heres a typical picture of the boards.
Some owners just install a canvas cover over the hatch.
The boards are angled to keep the water from seeping through. This generally works pretty well.
Heres a couple of approaches from H26/260 owners to ensure rainwater does not seep through the hatch boards. John Denisons solution: I used the the brass strip that bridges between linoleum floors. It is mostly flat with a bit of an edge on one side. The double sided tape is just 3/4 wide foam tape. Since doing this I have not had any water in the boat and it only cost about $6 or $8 to make. Then I made a storage rack for them, also in the knowledgebase forum. Since doing this I have had no water in the boat! Finished hatch boards
I used double sided foam tape and the screws provided.
Strips in place.
End view Heres Pat Adams Approach: I used starboard available in a variety of colors, thicknesses and sizes at West Marine. I re-used the original lexan pieces.
