Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Boomkicker
posted 09-12-2008 by James Seamans
The stock H260 comes with a topping life to keep the boom up when the main is furled. The Boomkicker is a relatively inexpensive alternative to the solid vang found on more expensive boats. The advantages of the Boomkicker can be found on the manufacturers website http://www.boomkicker.com
