Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Last Winters project: CabinWay Doors
posted 10-07-2008 by Michael Bell
See CabinWay Doors Open
I cut a pattern from cardboard to get the overall shape. The doors are made from laminated 1/4 inch oak plywood. The Plexiglas ports are sandwiched into the construction.
See CabinWay Doors Shut
The door was fitted with hinges and attached for correct fit, then was cut in half down the middle.
See Another View of them closed
Yaquina Bay bridge in the background. Newport, Oregon (thats Orygun by the way)
See Cabinway Doors from the top
I used a removable hinge so that it was easy to store the door below when not needed. This picture shows the overlap construction I used to keep it water tight. It was a long and difficult project, but with the doors on the boat only a day now, Im thinking it was worth it.
Click image for largest view
