Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
DC Electrical Panel Upgrade
posted 01-21-2017 by Doug J
Click for larger view
Blue Sea 13-Position Breaker Panel w/Volt and Ammeter
Here you can see the OEM fused switch panel.
The original only had 5 positions.
There is enough room to accommodate this lager panel.
Panel comes pre-wired, just need to make all the desired connections for equipment/accessories.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
