Hunter 240 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H240/260 Motor Mounts
posted 10-07-2008 by Jim Seamans
See Transom
As some of you might remember last October 2001, I advised everyone to check their motor mounts for twisting and bending. Hunter did send me a new set for my H260 and also is the same mounts for the H240. I deceided to make a different and stronger mount.
See Heavy duty
This is 1/4 wall high grade aluminum 6 and 4 long with the proper holes.
See Different view of mounts
You can see this stuff is thick
Click image for largest view
